Overlay graph not aligned with active roast
When overlaying a roast, the two graphs are not aligned — the overlay is always slightly shifted to the right. You can see this clearly when overlaying the same roast as the one you’re viewing. Example here:
It’s the same issue when overlaying a roast in the active roast tab. This makes it quite hard to actually follow an overlayed roast.
