Currently you can only enter grams for the Green coffee weight, It would be beneficial to be able to swap input measurements to oz. I believe it could be implemented to change when you change temperature measurements to from Centigrade to Fahrenheit . or just a dropdown in the roast editing menu. Thank you.
Hello @prehistoricperksfut,
You should be able to change this here: Roast World - Cup, grade, and analyze your coffee roasts in depth when choosing your Weight Systems. KGs and LBs are the options and so to get OZ, you can switch to using lbs.
And that will affect the roast world software input weight?
