I have seen this power, fan, and drum speed setting in the preheating menu.
I know that the preheating process always works as default only.
Does anyone know why these control options are given in the preheating setting (in the recipe)?
I could be wrong, but I believe that in recipes, the parameters in the pre-heat rung of the ladder are what is passed to the roast profile.
So if you had P7, F2, and D6 in your pre heat rung, After you add your beans and the bullet tells you “Now Roasting” the roast parameters will be P7,F2, and D6.
