Hi all.
I have been roasting on the R1 for a while using Celsius. I am about to roast on a 20kg roaster that the owners have in Farenheit. Would any one know how to convert RoR celsius to farenheit? Is there a chart out there? Thanks for your time!
You shouldn’t need a chart for ROR. Delta T of 1 C is 1.8 F.
Hi,
You can go to profile pic - Edit Settings - Roast Config - Unit of Temperature
Set the unit to Fahrenheit and save changes. The B-ROR in your roast profiles will be converted to F/m. You can change it back if you need to roast in degrees Celcius afterward.
Best regards,
Kevin
Cool, thank you!
Hi Kevin,
Ok cool. I will do that and match the readings. Thank you for the suggestion ![]()
I made one on a spreadsheet like excel or google sheets. 1 put 1 to 24 in one column for Celcius and the formula =(b2*(9/5)) in the next column. B2 represents the cell where the first value is. Copy it down the column. Its 1.8 F for each 1 C
ROR
C. F
1.8 - 3.6
- 5.4
