I don’t know how much help I can be for you.
I use recipes for most of my roasts.
I use the IBTS for most of the rungs of my ladder.
I really don’t use the time as a controlling factor in my recipes, with one exception. If I want a 1 minute dwell after pre-heat I will put in time values.
Here is an example of how I use a recipe:
I set up the preheat. It might look like this:
After the Bullet has reached 518F and soaked the drum for about 10 minutes (I don’t have any control over how long the pre-heat will take)
The bullet will say “Charge” Then I load the green beans and the Bullet will then say: “Now roasting”
The Bullet will now begin the roast with the settings from the pre-heat, showing P7, F2,and D9
If I want the beans to “soak” for one minute at power level 7, my first rung of the ladder will be 199F & Time > 1:00 Change the power to 9. After one minute at P7, the power will change to P9.
After that, I change all of the times to 1:05 for the rest of the rungs and only control the roast with the Power, Fan, and Drum, setting based upon temperature.
I have not tried to control the bullet with times on every rung.
I was looking at your Recipe and you have times entered for every rung.
That should be okay, but I am unsure of how you have the times setup.
The first 3 rungs after Pre-heat, show increasing times, but on rungs 4, 5, 6, you drop the time back to 1:30. I am not sure which takes priority for the rungs, temperature or time.
I could be wrong, but the way that I think about this is:
I want the changes in Power, Fan, and Drum Speed, to be based upon temperature. I don’t want to stall the roast if it reaches first crack temperature and then has to wait for several minutes before the time will allow it to go to the next rung. I can’t even visualize what the graph might look like for that situation.
If we think about how coffee was roasted before we could record time and temperature, most of the decisions were made based upon smell, sound and color of the beans.
As I said: I could be all wrong on this. These are just my thoughts.
Edit: Your roast profiles look very good.Ratios, RORs and the main curves make me jealous.
Edit, Edit: I borrowed your Colombia Recipe, cloned it and I will run a 600g batch on some Colombian beans that I have. My OCD demands it.
