If I pick IBTS for ROR in the config will my bean temp still be read by the IBTS?
Currently both I-RoR & B-RoR are plotted. Selecting IBTS places the Markers (Yellow, 1C. 1Cend, etc.) on the IBTS temp plot; choosing Bean Temp just locates those markers on the plot for the Bean Temp. Either way youāll (at least currently) have both RoR curves.
Iām confused by this reply, Bruce. Arenāt the IBTS and ābeanā plots just temperature plots? The RoR is a rate, right? Change in temperature per minute? Thereās only one RoR curve plotted. Or am I missing something here?
Terry
Yes, thatās correct, but you can plot it for BT (thatās usually used) and additially for ET
Latest version of Roastime implemented IBTS ROR.
Hi Terry-
Yes⦠RoR is the rate of change of IBTS & Bean Probe temp graphs in degrees per min.
Depending on your installed version of RT3 you should be seeing a smoothed I-RoR plus B-RoR. The latter (B-RoR) should be unchanged from what youāre accustomed to seeing.
RT3 ought to auto-d/l a newer version then offer to update RT3 to that newest version (RT3.1.1).
In use during a roast, I-RoR starts out off the chart and drops into view (at least on my usual profile) at about 3 min into the roast. That initial off-scale behavior is caused by the initial steep slope of IBTS. That means I-RoR is such a large value initially that auto-ranging of Y2 set a scale so high it made data that arrives later unusable because it was compressed near the X axis.
So the plan now should be to set Roast Config for Y2 axis to something that makes both I-RoR & B-RoR readable during a roast (I chose Y2 = 40)ā¦
I donāt see I-RoR on recent charts I view on R.W⦠probably coming soon, but for now you can view the newer charts in RT3.
Youāre right, @bab . This isnāt available yet in RW. However, we do have plans to get this over to RW. Currently, Iām caught up with some support-specific work though. So this will more than likely be added to RW after that.
Having both ibts and bt RORs visible has been one of the best things of RT 3+. I make my P and F changes based on IBTS but as you mentioned, the initial few minutes of the i-ror is unusable. Post yellowing, it is a useful tool. So, my recent roasts have been based on b-ror initially, then i-ror and a delta temp, dtr and target temp combo, which provides a very holistic approach, IMHO.
