Roastime 4.13.6 Third back-to-back roast was never logged
The third roast of yesterday, working from a recipe, never took hold in the software. Oddly enough, Roast World very prematurely advised the roast was nearly done (it wasn’t). Roast World shows no record at all of that activity. It was as if the Bullet was able to follow the recipe all by itself.
Hi Ted,
I pulled the logs for your first two roasts from that session, and they look fine: both started cleanly, followed their recipes and saved with no gaps in the data.
The early “nearly done” message
That’s a bug in Roast World 1.215.0, and it’s fixed in 1.215.1. At charge, the app compared your recipe’s end temperature with the IBTS reading from the hot, empty drum. Back-to-back roasts charge hotter, which is likely why only your third roast showed the message. Updating to 1.215.1 or later fixes it.
Why roast 3 wasn’t saved
The Bullet can’t run a recipe by itself. Roast World sends each recipe step to the roaster, so the app was connected and running roast 3. The roast was lost at the end, when it should have been saved. The most likely cause is a brief connection drop between Roast World and the roaster that only recovered after the roast had moved into cooling. When that happens, the app doesn’t recognise the end of the roast and discards it without a message.
We haven’t confirmed this yet, so it would help to know:
  • What did the screen show during roast 3? Were the graph and roast timer running?
  • During that roast, did you see a disconnect, did the app restart, or did the PC go to sleep?
