UPDATE: I was able to get RoasTime running by deleting the ~/. config/RoasTime folder and relaunching. Fortunately my data was all still there. Just had to reset the theme as it had reverted to the original.
After RoasTime auto-updated it no longer opens on Linux. The same error happens with RoasTime freshly downloaded:
Failed to load GLES library: /tmp/.mount_RoasTiNeoU6r/libGLESv2.so: /tmp/.mount_RoasTiNeoU6r/libGLESv2.so: cannot open shared object file: No such file or directory
Is there a way to stop the auto updates or revert to the previous version so the software can be used?
After moving the .AppImage to a new folder it technically opens but results in the following error:
" Error: backend/unavailable
Failed to connect to RoasTime’s backend after retrying 5 times. Restart RoasTime to try again."
Restarting does not help. This is certainly frustrating as I have a lot of roast recipes, profiles, data that I do not want to lose. How can I get RoasTime up and running without losing my data?
