Removed RT2.5.7, which I had left on after RT upgrade, and white screen issue has stopped.
Reinstalled RT3.1.8 and added the RoasTime.exe file to McAfee’s excluded file list as shown in the screen shot above. So far no issues with the icon going white and no error messages about the shortcut path not working.
Just got done roasting a batch of coffee with no issues. RT and the Bullet both worked perfectly.
Glad you guys got it working - yeah, as Jacob mentioned, the 2 aren’t meant to be running side by side since they share a directory structure. So each time you open the other one, it causes a data corruption issue.
I will see if I can’t figure out why Mcafee is flagging us.
Seemed like RT 3.1.8 worked ok. But when I did the update McAfee removed the excluded files because they were updated. Now RT won’t open at all. Icon still remains but nothing happens. And McAfee keeps removing the files each time after I add them to the excluded list.
Update Uninstalled RT3.1.9 again. Reinstalled 3.1.8 and skipped the update. Seemed to work fine before the update yesterday, so just going to stick with that for now.
Ok I am now having same problem but with Trend Micro anti virus software. Even when I click “Trust this Program” it just keeps repeating and nothing happens. Has only happened since RT software update.
@mcaillio I reinstalled Trend Micro to bypass the issue and it works now. However I lost the history of files blocked. The file would have been the Aillio RoastTime update exe file, as it just blocked RT after doing the update
It might be interesting to verify which file Trend Micro Folder Shield is protecting. From the TM website:
Your Trend Micro security software can prevent ransomware from maliciously encrypting your files and holding them hostage until you pay the attacker. Folder Shield adds an extra layer of defense that limits access to files within the protected folder.
Trend Micro has a standard approach to Block any exe file trying to make changes to hard drive. Normally, you just click “Trust this file” to allow it to proceed, but this time it just kept looping back to block the file.
It was definitely the RT file to upgrade from RT 3.1.8 to 3.1.9 as I had just initiated the update download. The update file would have been trying to overwrite the previous RT on HDD version so TM stepped in.
Given it is now working fine after TM reinstall, I assume it was a problem with TM not RT.
