Page 48 of the Operation Manual (V2.7) indicates that in order to change settings (Units, file location, Visuals, etc.), “press the “Settings” button on the bottom right of Roast Time”. I am not seeing this button on my screen. The “Settings” wheel on the upper right of the screen only provides updates for temp and UI mode. How can I access all of the settings in this version? I am using RoasTime 2.0.8-beta and the 475 Beta Release firmware. Thanks!
hit the 3 squally lines on the left. then you will see the wheel setting or the far right. The only options I show up are “roasting UI mode and temperature”.
