RoasTime Suggestions after months of use
One thing that would be amazing is if toggling from “Roasts” to the “Active” tab didn’t revert the “Roasts” tab back to default top of page. I will often seek out a roast, click for more details, maybe even overlay the roast, then toggle to my “Active” tab while roasting and when I go back to “Roasts” tab the page resets and finding the roast again without any roasting numbers assigned is very cumbersome!
That being said, it would be lovely if each roast received a roast number. Other software I’ve used does this and it’s very helpful for tracking. PR305 for instance. Easy to write down, reference and find in a pinch.
Another amazing feature would be during overlays, to display more information from the overlaid roasts within the “active” tab. I will often have an overlay and want to double check DTR or end temperature only to have to navigate back to the “Roasts” tab and face the aforementioned problem of tracking down the roast again from the top of the page.
Thank you very much for hearing my thoughts about improving RoasTime!
I have 4.13.6 currently installed.
I ended up using the title templates in roasttime (you can find it in the settings) to append the roast number to the end of the roast name. It works pretty well.
Nice thanks! I was unaware of this feature!
Also I realized since positing that when in the Active tab, the overlay roast has a hyperlink on it on the left side of the screen and when clicked takes you to the roast details which is perfect!! It fixes the issues I had with scrambling in the Roasts tab every time I went back to it!
