Seasoning roast not reaching 2nd crack
I finally have everything set up and my first roast didn’t make it second crack before it overheated and shut down (around 29 minutes), the second seasoning roast didn’t make it to FC (28 min). When working on a share machine FC happened before 10 minutes. I’m in Japan and wonder if it could be a power issue? I have the 220v EU machine with a power converter. Maybe the power converter is weak? Any thoughts would be appreciated.
Hi @johakyucoffee.my7u,
Have you already connected the Bullet to RoasTime 4 for your seasoning roasts? We could not find your roasts on RoastWorld. If you haven’t, could you send an email to [email protected] with some videos attached?
Best regards,
Kevin
