Smoke between batches
Hey everyone,
Is it normal to have smoke coming out the vent exhaust between batches?
After around batch 4 going up, smoke will not stop throughout the pre-heat stage and up until i charge the next batch.
If this isn’t normal, could the reason be that the air inlet is clogged be chaff?
That is not normal.
Smoke should not be coming out of the machine between batches.
Hi @gdegde481.i9qy1,
You might need to share some pictures or videos; if you’re not comfortable with sharing them here on RoastWorld, we would suggest contacting [email protected].
Best regards,
Kevin
