Splash Screen
How about adding a Splash Screen when starting the software. Roastime takes quite a while to start up, and most of the time I end up with two instances running, because I cannot tell if the software is starting up, so I execute it again.
I would think adding a startup screen is pretty simple?
Thx.
-Mark
What is quite a while in your case ? Mine is only about five or ten seconds in line with other software on my laptop…
Mine takes over 30 seconds.
Mine’s in the 5-10 sec range too. I suspect it’s version-dependent… ??
What are the specs on your laptop @skioutwest - 30 seconds is definitely high.
It is an older machine that I dedicated to the roaster. Its a Core i5 2.2 ghz with 8 gig ram on Win64.
Part of my problem is that I am starting the software during the startup sequence. Just timed it and it took 1:45 for the software frame to appear, then an addition minute for the frame to populate. This issue I have is that there is just no indication that I executed it, but sounds like this issue is unique to me.
Once the system is up and running, it takes about 10 seconds to start it up.
-Mark
Those specs are actually pretty good. Is this MacOS or Windows? Maybe something to do with starting in the startup sequence if it starts quickly once you are running.
