I often want to change the second crack time after I’m done with a roast. But the drop-down menu for crack times runs off the bottom of the screen. I can’t change them manually. It does not save the corrected times.
Try going fullscreen - F11 or Fn+F11 Windows, Fn + F or Control + Command + F Mac. Also check your scaling settings if using Windows. If you’ve already tried these, I’ll try to think of something else.
