Time trigger warning saying active despite advnaced settings switch off. Not sure what to do with this…
Advanced setting just hides the time. If you don’t want to use time, enable advanced settings, then set all times to 5s. Save.
Does this have to be done for each rung of the ladder? Or is there a way of changing all of the times to 5s at one time?
There is a Clear Timer button (which could use a better description)
This sets all time triggers to default 5s.
Great.
Thanks
