Unable to connect Roastime (4.13.6)
MacOS. Cable tested and works. Deleted dependencies. Any help appreciated.
This doesn’t detected any devices: “ioreg -p IOUSB -l -w 0 | grep Roast”. I’ve checked and reset my settings so that accessories are allowed.
Hey,
You probably know this, but just to make sure, ioreg -p IOUSB -l -w 0 | grep Roast would probably not return anything even if it were there since the name is typically STMicroelectronics Aillio LTD- Bullet R1 ROASTER FS and grep is case sensitive, so you would want to ioreg -p IOUSB -l -w 0 | grep ROAST.
Is this a new Mac (m-series)? Or is this a new issue on an Intel distribution that was working before?
heya - thanks for the reply. I wasn’t aware of the official name so thanks for telling me. I made the grep case insensitive (“grep -i”) and got some hits (should’ve thought of making it case-insensitive by defaut!):
+-o Aillio LTD- Bullet R1 ROASTER FS@00100000  <class IOUSBHostDevice, id 0x10000fdc2, !registered, !matched, inactive, busy 2 (2729 ms), retain 24>
|     "sessionID" = 1021205119187
|     "USBSpeed" = 1
|     "UsbLinkSpeed" = 12000000
|     "idProduct" = 41598
|     "iManufacturer" = 1
|     "bDeviceClass" = 0
|     "IOPowerManagement" = {"DesiredPowerState"=2,"PowerOverrideOn"=Yes,"CapabilityFlags"=0,"MaxPowerState"=2,"DevicePowerState"=2,"DriverPowerState"=0,"CurrentPowerState"=0}
|     "bcdDevice" = 512
|     "bMaxPacketSize0" = 64
|     "iProduct" = 2
|     "iSerialNumber" = 3
|     "bNumConfigurations" = 1
|     "UsbDeviceSignature" = <83047ea200023030303030303030303230300000000202010a0000>
|     "USB Product Name" = "Aillio LTD_ Bullet R1 ROASTER F"
|     "locationID" = 1048576
|     "bDeviceSubClass" = 0
|     "bcdUSB" = 512
|     "kUSBSerialNumberString" = "000000000200"
|     "USB Address" = 1
|     "IOCFPlugInTypes" = {"9dc7b780-9ec0-11d4-a54f-000a27052861"="IOUSBHostFamily.kext/Contents/PlugIns/IOUSBLib.bundle"}
|     "kUSBCurrentConfiguration" = 1
|     "bDeviceProtocol" = 0
|     "USBPortType" = 5
|     "IOServiceDEXTEntitlements" = (("com.apple.developer.driverkit.transport.usb"))
|     "USB Vendor Name" = "STMicroelectronics"
|     "Device Speed" = 1
|     "idVendor" = 1155
|     "kUSBProductString" = "Aillio LTD- Bullet R1 ROASTER FS"
|     "USB Serial Number" = "000000000200"
|     "kUSBAddress" = 1
|     "kUSBVendorString" = "STMicroelectronics"
+-o Aillio LTD- Bullet R1 ROASTER FS@00100000  <class IOUSBHostDevice, id 0x10000fdd4, !registered, !matched, inactive, busy 2 (1734 ms), retain 25>
      "sessionID" = 1021228996323
      "USBSpeed" = 1
      "idProduct" = 41598
      "iManufacturer" = 1
      "bDeviceClass" = 0
      "bcdDevice" = 512
      "iProduct" = 2
      "iSerialNumber" = 3
      "bcdUSB" = 512
      "USB Address" = 1
      "USBPortType" = 5
      "Device Speed" = 1
      "idVendor" = 1155
      "kUSBAddress" = 1
It’s an m-series running an m3 chip. It was working before but would stop once in a while after an update. I remember fixing such issues after redownloading ARM releases from the website (usually the same build as mine would auto-update anyway).
