Since the last update, I can no longer see as much of my roast curve as I previously could during roasting. I used to be able to see as high up the curve as the ror predict line pointed. Now I can not even see first crack until I am almost there, the screen doesn’t show anything above 180 degrees. This is frustratingly unworkable. I want to be able to see the whole curve right from the beginning. How do I accomplish this??
Is this the same for everyone else? Are any of you able to see more of your overlay than this? Or is it cutting the end off of yours as well?
The defaults are controlled from your Chart Default Settings (X, Y, Y2 axis). I wasn’t aware of any change related to this, but maybe your settings got overwritten.
Oh my gosh! I didn’t know those settings were there! Thank you so much! That solved it.
