V4.14.3 Connection Issues
I’m having connection issues after upgrading my R1 v2 to v4.14.3. I thought the issues was resolved in v4.8? Anyone else having this issue. I’ve also had the SW lock up in the middle of a roast.
I Have also trouble with RoasTime 4.14.3. I installed RoasTime 4.13.6 and I can control the roaster.
Where did you get 4.13.6? I can’t find any other versions on the roast time website.
https://releases.roast.world/roastime-main/v4.13.6/mac-arm64/RoasTime-mac-arm64.dmg
Thanks, but it doesn’t help. I’m running windows 10.
If you check the URL from which you’re downloading your current version and then compare it to the URL of my previous version, you might be able to figure out the URL for the previous version you need.
Hi Fred, I see that you have since been roasting. How did you fix your issue?
Has anybody used this version on Apple Mac’s new macOS Golden Gate? I don’t want to upgrade until I know that this is going to work okay.
I can’t find v4.81 on the link, it only shows v4.14.3 when I go to the download page.
Pretty frustrating! Is that a Windows 10 thing?
Still having issues. The SW team has verified that my configuration is correct but I’m still having dropouts. The main issue right now is that the connection is toggling between offline and connected. What is frustrating is that I’m not sure how to troubleshoot the problem. Is it the SW, my computer or the roaster itself. My computer sees the roaster and it might show connected on the UI, but then will drop out. I’m also getting intermittent windows notification stating that there is something wrong with the USB device (roaster). Any help would be appreciated.
