Hi all. I am currently on track to opening an e-commerce based, tiny roasting business in Seattle (excited!). We found a prospective space where the landlord is allowing us to roast with our Bullet. (I cannot roast any longer from home as neighbors are not happy about smoke). That being said, there is one thing about the space that is concerning to us.
The window that comes with the space is a casement-type (cracks outward instead of the sliding type). Because I am not well-versed in ventilation, now I’m not sure how we can effectively and safely vent the smoke. In a perfect world, my thought was to attach one of these window vent to a sliding window: https://a.co/d/eSDWRhi
If anyone wouldn’t mind sharing their setups or ideas regarding venting through casement windows I would love to learn about them! Thank you.
If you look at the ventilation-related articles on this forum, you’ll find a lot of ideas regarding ducting, fans, etc. An important consideration is where your make-up air is going to come from - is there another window or opening that will allow clean air in?
Hi John. I did check out the ventilation articles and bought some essentials such as the cloudline s4 fan, duct hoses, exhaust adapters etc. However, I couldn’t seem to find a setup that works around casement windows yet… (I’ll look again!). As for make-up air, there is another casement window on the other side. I hope that is enough for the Bullet…
Are you objecting to being not able to seal around the vent pipe going through the window so you can keep the weather out?
Elsewise, just stick an easily removable piece of flex duct through the gap at the bottom, perhaps angling towards the central, fixed part of the window, whenever you roast and remove in between roasts. Unless there is a strong wind towards your window, most of the smoke should rise from the hot air and stay outside.
If you want something more permanent/sealed, cut a piece of plywood with a hole for the vent to insert between the bottom of the window and the bottom of the frame when the window is open to its fullest extent. Then cut and tape a pair of triangular gussets out of polyethylene sheeting to seal the sides. When you are done roasting, remove the plywood and close the window. The gussets should accordion and not need removing.
