Hi all,
It seems like the alarm speaker on my roaster has stopped working. It has been very faint for the past year and now seems to be completely off-line. Is it possible to replace this? Wasn’t able to find a part in my initial search.
Thanks! Rob
Hi all,
Thanks! Rob
Depending on where you are you can contact your local distributor or Aillio directly.
Just make sure you have not just turned down the volume by accident before you buy. See the manual how to change the speaker volume.
Thanks! Yes, I’ve got the volume maxed out. I’ll check into getting a new one.
