I’ve read these don’t work together. With Artisan I’ve tried just importing a json file to analyse which gives error codes. Anyone had any success? I have read this here but it seems perhaps not as current. https://www.home-barista.com/home-roasting/artisan-2-0-and-aillio-bullet-r1-v2-t64271.html
Artisan 2.x and Bullet r1v2?
Artisan can be used if you install the legacy drivers if you’re on Windows. You can’t run RoasTime and Artisan on the same machine due to driver differences. What json file are you trying to import ?
There is a build of Artisan for the Mac and it should support the Aillio(s) as a device across all the platforms, so no reason it wouldn’t. I seem to recall Marko mentioning there was a MacOS issue with the latest “stable” build so he advised using the nightly/developer build instead which has the issue fixed. Something Apple changed at the last minute which caught them out.
That should allow you to switch out the software of your choice - Windows RoasTime and MacOS Artisan…just move the USB cable…
