I have left the Command Prompt for as much as an hour and found it still hung. The executable file is aillio_driver_update.exe. The text in the prompt window is:
Extracting driver files…
Success
Installing driver(s)…
USB\VID0483&PID_A27E&REV_0200:
From the first time I have encountered this issue, the Bullet’s recording of “The Bullet is Ready” has been corrupted so that it ends with a horrifying screech. Otherwise, everything seems to work perfectly.
RT3.4.1 has an issue with d/l’ing drivers. Typically you would need to install RT2.5.x to do the d/l then revert to RT3. The driver d/l issue is resolved (? at least for my Win10/11 installation) in RT4. You may have some reason to continue with RT3 but for my purposes the move to RT4 has been a success. If you need to stay with RT3 then the advise from @jeffaillio is the way to go.
Aillio support sent me a sound file update executable. The sound files should work correctly now. The first on “The Bullet is now ready” definitely does.
