Hi,
As per bullet R1 manual chaff collector shall be unattached when performing fan calibration, but when I try to perform fan calibration while chaff collector unattached it would not start unless I attached it then it would start. is this normal!!
Hi,
Yes, if you live in Europe, or you don’t, but you still have a 220V CE certified Bullet.
Bullet R1 Manual - Google Docs
If that’s not the case, and you’ve tried to make it work by following the manual, contact support. Maybe update your firmware if you haven’t in a while.
Thanks for your reply, not living in Europe but I do have 220v machine ( which is our default power voltage) and firmware already updated to latest. But still can’t do fan calibration unless chaff collector is attached.
Just click the link that I left above. The manual describes the operation in detail. I’ll copy/paste just in case…
Many thanks
Many thanks +1
