When I roast 500 Grams at Drum speed 6 or 7 I hear FC no problem, at Drum Speed 9, I cannot hear FC is this normal?
First crack can be difficult to hear. Some beans it is more clearly heard and some not so much. I don’t use that low drum speed for long enough to reach FC at that speed so I can’t tell you if there is a difference between hearing it at D6/D7 vs. D8/D9 for the same bean. Second crack can also be difficult to hear if FC is difficult to hear for the particular bean.
Here is a thread discussing all sort of hacks for better hearing FC.
Interesting… What I failed to say, was that this happens a D9 with 750 Grams of Green… seems I can make it out no issue, with 500 grams as the drum speed is less. Maybe its time to invest in a stethoscope. LOL :)))
I use one of the hacks of silicone tubing in bean sample port. Fits very snuggly. It then has a small microphone inserted in other end of tubing. Mic plugs into my laptop and I play mic through laptop speakers.
Normally how loud FC is is depended on how strong the heat was applied to the bean from when you charged it until FC. if you have a 7-8 minute roast to crack it would be louder compared to a 11-12 minute charge to FC. Hope I helps.
