Forced RoasTime update, migration to new Bean Inventory system today (3/7)
Update for RoasTime not quitting. It appears to be a rather common problem.
What I discovered is that when attempting to quit the program was thatI noticed a small window appearing in the center of the screen. After a second or so the small window disappears. After several attempts to read the text in the rapidly disappearing window I found that it says "Are you sure you want to quit. Then below are No and Yes boxes to click. Apparently No is the default when it disappears. I was able to place my cursor near where the yes box would appear, use command Q to quit and then very quickly click the yes box before it disappeared. Now the program quits.
Could someone please fix the disappearing window - or- make yes the default. THANK YOU!!!
Hi Geoffrey - On my MacBook Air fully quitting is now a two-step process. First close the RoasTime window with the red X at top left, and acknowledge in the pop-up dialog. Then in the top bar RoasTime > Quit RoasTime. Strange, but not a big deal. Hope this works for you too. - Brad
Hi Brad
I tried it. The box appears after clicking the red X. I then click on the yes button and the window disappears. BUT- The program is still on as seen by the black dot under it’s icon on my menu bar at the bottom of the screen. I still see the program is available to force quit. Are you sure your RoasTime program is shut down?
Edit- I just tried it again the way I described above using command Q and finding and clicking the yes box before it disappears. That apparently does close the program on my MacBook Air. Weird.
Yes I also get the black dot under the RoasTime icon after closing the window and acknowledging in the pop-up dialog. At that point RoastTime is still visible in the top bar, and I can click it to open the drop-down menu and Quit (or use command-Q). This second part might not be obvious if you have other apps running and one of them becomes active.
The whole issue seems to be that we expect selecting Quit in the RoasTime menu to both close the window (command-W) and close the app (command-Q). Today these actions need to be performed separately.
That worked. Thanks Brad.
Just FYI that I am working on this for next release. This seems to be an issue with the background log sync stalling. @geoffreychilds @bradm
you should pin this one or make the announcement more clear. I tried to resync from the roasts page but couldn’t get it to update. This took a bit of digging to find
Thanks for the feedback @fwbennies. This was pinned globally but it seems like the pinned duration expired. Will pin again.
@derrxb Hey Derrick, I am still unable to filter My Roasts by Bean Name in RT. I think it may only be recognising new beans added since migration?? Would that be right?
Is there an easy fix or do i need to manually adjust each Bean balance?
Also, in RW, when I select a Bean, it used to show me only my roasts using that bean and I could select other users to show all user roasts using that bean. Now it defaults to All Users, am I able to return settings to just My Roasts initially?
I am on RT 3.4.1 and have logged out and back in and done re-sync with RW beans.
Thanks
Hey @snidely_whiplash, sorry for the delayed response. I was off last week. I’m currently looking into this. It seems like some other users might be experiencing something similar. You can follow None of my bean inventory is available in RoasTime - #4 by coffee_mook to see updates on this.
Thanks @derrxb , following
