Garbled speaker/screech on startup
Video of speaker noise on startup
Has anyone had this before? I just picked this roaster up used. The speaker generally seems to work ok after the initial startup but upon the initial boot it makes a static, screeching sound when announcing itself. If I had to guess the speaker is bad but I don’t see anyone else in the forum that has had this particular issue. The control panel itself seems to work as expected.
If anyone has any insight that would be appreciated.
There was an issue with a firmware update about a year ago that caused a similar problem.
Since you have a used Bullet, the firmware may be the culprit.
Thanks @billc, I neglected to mention the first thing I did was update the firmware to the latest. It was on 602.
I will check out what the other folks did in that thread and see if I can get it to fix my issue.
You might need to reach out to [email protected] for help with fixing this.
Derrick
Support has an app you can use on windows to restore the sounds.
Thanks all, I have reached out to support.
In case anyone comes across this later support was able to resolve my issue. Once I ran the provided sound updater the issue was gone.
