New R2 Pro Setup, But Extremely Unhealthy/Hazardous
Hey everyone,
I am back to provide an update on this issue, since I was busy with Holy Week and Easter previously and could not do much about it.
TLDR: My Bullet R2 Pro is definitely leaking smoke through the induction fan on the left side. I am now seeing warranty repair.
Updates to the Ventilation Setup
After reading all the helpful comments and tips by others here, I decided to get rid of as much flexible hosing as possible and focus on rigid metal ducting. My setup is now comprised of the following components from the roaster up to the vent:
  1. Vent hood over the exhaust port of the Bullet. I also have the 3D-printed adapter installed on the exhaust port to help direct the smoke up into the vent hood.
  2. Metal duct splitter with 6" fittings and a 4" Y-split for the cooling tray fan
  3. Metal adjustable elbow
  4. 36" metal duct
  5. AC Infinity S6 Pro fan
  6. Small section of flexible hose (about 18")
  7. Semi-rigid aluminum elbow connected to the vent hood w/ damper termination to outside.
I forgot to take a photo, but will do so shortly. Hopefully this description makes sense. In essence, it is a 90% metal construction with each piece securely fastened and confirmed to have no leaks.
New Air Purifier
In addition, I placed a new Levoit Plasma Pro Core 300S Smart Air Purifier next to the roaster. This runs at full blast during roasting.
First Test with New Setup
Optimistic about this new setup, I just tried an 1100g roast, which is my usual batch size. Everything was promising at the beginning with the PM 2.5 levels at GOOD until dry end. From there, they followed the same progression as when I had flexible hose. The particulate levels begin to elevate at dry end and then really shoot up into HAZARDOUS territory on the monitor around first crack until the end of the roast.
I marveled at why the smell of the roasting coffee was so strong in the room during the roast and decided to position the AQ monitor directly in front of the induction fan at the left side of the roaster. Sure enough, when it was positioned there, the numbers rapidly increase, but when I removed the monitor to its usual position, it tapered down a bit.
This leads me to the conclusion that the problem is not my ventilation setup, especially this new one with metal ducting. The problem is smoke leaking from something other than the exhaust port. This points to a problem with the Bullet R2 Pro itself, because I don’t think smoke is supposed to leak from any point other than the exhaust port.
In addition:
  • The problem is not airflow or makeup air in my setup, because I have both a window and door fully open behind me letting in plenty of air for the AC Infinity fan to do its job.
  • The problem is not the AC Infinity fan, because it is pushing a lot of smoke out through the vent termination outside. Also, at one point, I had TWO S6 Pros working in tandem, but the result was the same. My fan is sufficient and is doing a great job. The issue is that it is venting what’s coming out of the exhaust port of the roaster, which is a lot, but not the only source of smoke. I suppose I could add another 4" Y and put a duct boot in front of the induction cooling fan to vent that smoke, but that shouldn’t be necessary as I don’t think that should be an exhaust source.
  • The problem is not the exhaust fan of the roaster. I confirmed that it is working well and responding to different fan speeds (F2-F12).
  • The problem is not the Temtop Air Quality monitor. Even the built-in monitor on the air purifier reports high PM 2.5 numbers.
Next Steps
This thread has been viewed and discussed quite a bit, especially by prospective owners who reached out to ask about my experience. Many people have done their best to offer suggestions and help, and I have likewise done my best to try whatever was suggested.
In light of this, I plan to contact Sweet Maria’s from which I bought the Bullet R2 Pro back in January 2025 (yes, it’s only 4 mos. old) and Aillio to figure out what needs to be done under the warranty. I have not only followed the recommendations for ventilation from the R2 Pro manual, but also spent a good deal of time and money on additional things (like metal ducting, air purifiers, filters, adapters, different hoses, extra fans, smoke pens, etc.) to make this work as it should. Aillio specifically recommends against using the Bullet outdoors in their manual, so my expectation that this should work indoors with a proper ventilation setup is not unreasonable.
As always, I am open to more ideas, but at this point, I feel like I’ve done all I can and more.
This was my thoughts as well as I also use a s6 inline fan similar set up without the extras and seems to vent well but need to check with a air monitor as I am definitely concerned and curios now as to how well it vents now. Thanks for bringing this to the attention of others on this forum.
Few things you could consider.
Could try adjusting the shims to get the drum a tad more forward, that should seal this more to the front plate.
From your first posts about the PM2.5 particles your roaster seemed fine up until a point in mid March. Have you done any maintenance / deep cleaning?
After removing the front plate was it put correctly back together?
Any beans stuck under the drum giving off smoke?
As @itspaul suggested, a strong flashlight in the dark might help seeing where the smoke originates from.
Also, what is that thing you got in the tryer port?
Greetings, @jacob,
OK, I will try it tomorrow, God willing.
Yes, I have run through the deep cleaning protocol outlined in Aillio’s R2 maintenance videos since March. It was one of the first attempts to solve the problem, but it didn’t make a difference.
I believe so, but I will confirm after adjusting the shims tomorrow. As of now, everything seems to be put together according to spec.
When I last performed the deep cleaning around 2-3 weeks ago, I vacuumed the inside of, and under, the drum very well. One of my posts above shows there were beans stuck above the drum, but nothing was under the drum. Either way, I vacuumed everything 2-3 weeks ago and have been very careful when charging beans ever since.
I actually tried that earlier tonight. Nothing seemed obvious to me, but moving the monitor around suggests the source is around the induction fan at the bottom left of the roaster. That is where the smell is strongest and the monitor shows an increase in particulates rapidly.
Here is a video that shows the particulates increasing quickly after pointing the air quality monitor at the inducting fan at the bottom left of the R2 Pro.
https://www.dropbox.com/scl/fi/zgoc6eefafp3k2hcm9q6i/IMG_8329.mov?rlkey=6d4b5bkfv53kszzm5vxpwwlqx&dl=0
This is a heat-resistant silicone tube snugly inserted into the trier port with a little microphone snugly inserted at the other end. The mic goes to a small USB speaker, which allows me to hear first crack more easily. This ingenious idea comes from @billc and has been discussed on this forums elsewhere. I can assure you, however, that both ends are very snug and no smoke is escaping from the trier.
Lastly, here is a photo of the new setup with almost all metal ducting.
As I took this photo, I was testing something new: putting a small 4" duct boot right next to the induction fan on the bottom left of the roaster. While it did not entirely fix the issue (the air quality still degraded from dry end and ultimately reached UNHEALTHY by the end of the roast), I do feel it helped keep the numbers lower than before. I need to test more tomorrow and record actual values.
I hope this helps in finding a solution soon. Thank you
Hi @ibnabouna ,
I just did a roast today with my setup (see attached). I had the CO2 monitor the whole time from biggening to end. (I have the Bullet Pro). The CO2 level never went over the 600 mark the whole time. So, for me it is working well. As mentioned previously, I have the 3 D print exhaust, so I’m not sure if this is contributing to anything, but thought I’d still mention it.
All the best
That’s great news! I’m glad someone is able to use the machine without concern. Out of curiosity, does your monitor measure PM 2.5 or just CO2? I’m trying to figure out how those correlate.
Thank you. No, I don’t have the PM 2.5 (I don’t know what this is? If it is important, then I would return the device I have and buy another one that has the PM2.5).
I see that I have hPa (no idea what this is). It is at 986.
From Google AI:
PM2.5 refers to fine particulate matter in the air, defined as particles 2.5 micrometers or less in diameter. These tiny particles can be inhaled and cause health problems, especially for vulnerable groups like children, older adults, and those with heart or lung conditions.
More Information:
  • What it is:
PM2.5 is a mixture of tiny particles and droplets in the air, including organic chemicals, dust, soot, and metals.
  • How it affects health:
Exposure to PM2.5 can lead to various health issues, including respiratory problems, heart disease, and even premature death.
  • How it gets into your body:
PM2.5 particles can be inhaled and travel deep into the lungs, where they can enter the bloodstream.
  • Sources of PM2.5:
Common sources include vehicle exhaust, industrial emissions, wood burning, and wildfires.
hPa stands for hectopascal, a unit of atmospheric pressure
Yes, what @billc said. Because roasting coffee produces smoke with all kinds of particulates, measuring PM 2.5 and PM 10 (the numbers refer to the size of the particulates) is important to make sure that stuff is not getting into your lungs. With time, they can cause serious respiratory and health issues.
This is why I’ve invested so much time and money trying to get my setup in a good and healthy status.
@jacob
As a further update following your recommendations, here is what I did yesterday.
  1. I removed the face plate and moved the shims of the drum forward to ensure a good seal. In the process, I also vacuumed inside and underneath the drum to the best of my ability. After completing the test, I tried a 600g roast, but no luck; there was the same increase in unhealthy particulates around dry end and first crack.
  2. I purchased another PM 2.5 monitor (a Govee Home from Amazon), which measures only PM 2.5, temperature, and humidity. I figured fewer sensors might translate into higher accuracy. This is now the third monitor I have checking the air quality (1. Temtop Air Quality Monitor, 2. Levoit 300S Purifier, and 3. Govee Home Monitor). During the roast, I found all of them were more or less similar. The Temtop did have much higher values at different points, but the others ultimately caught up and all of them generally showed the same progression of higher PM 2.5 around dry end (~155 ĀŗC) and first crack (~190 ĀŗC).
  3. I watched an Aillio maintenance video about replacing the drum, so I went ahead and followed that procedure to fully remove the drum and inspect underneath it. I found some fine coffee powder (similar to what gets trapped on the face plate and bean chute), but no whole beans. It was a good opportunity to vacuum everything out fully before replacing the drum and putting everything together.
Sadly, in the process of doing all this to troubleshoot my issue, I accidentally dropped the face plate on the table and the screws holding the bean chute broke off. Thankfully, the chute and bean probe are fine; it’s just the screws. I contacted Sweet Maria’s for help in getting those screws so I can reattach the bean chute securely.
Moreover, for reasons unknown to me, the back side of the power plug of the cooling tray just came apart. Nothing happened; it just came apart. The end result is my cooling tray has no power and I can’t use it to cool the beans. I am in contact with Aillio about this, because the Pro Cooling Tray was supposed to be shipped out at the end of March, but I haven’t received it yet. I don’t know if it makes sense to replace/fix this standard cooling tray or wait for the promised Pro version soon.
Either way, it hasn’t been a great experience this week as the roaster is now out of commission and I can’t fulfill orders. In the past, even with the ventilation issue, I had the option of putting on a full respirator and roasting coffee, but now, between the ventilation issue and the broken bits, I can’t do anything.
@jacob , what do you recommend now?
Thanks for the info above. I’m gonna buy it for sure.
I think this is an easy fix that you can do quickly yourself. I understand that you’re still covered by warranty, but the pro cooling tray should get to you, and in the meantime you can get that one working. Maybe you know how, but here’s a link to the thread about it just in case.
What to use as a fan? - Taking Care of the Bullet - Roast World Community
I’m sure you’ll get the necessary help from Aillio, but just thought this might be useful.
Thanks, @braca19452f9m , that is super helpful. Aillio is sending me new power cables and a tutorial as to how I can replace it (kudos to Aillio for the good customer support in this issue), but the suggestions in your thread might help me get back to roasting more quickly.
Today, I continued working on the setup by replacing the very last bit of flex tube with a metal elbow. Now, my ventilation is all 6" metal ducting powered by a 6" AC Infinity S6 fan.
I ran several tests to ensure there was no air leak from the ventilation. Everything is tight and working as it should.
When running a test a few minutes ago with some seasoning beans, the result was the same as before. Around dry end, the PM 2.5 levels shot up to unhealthy levels. I aborted the roast.
At this point, I believe I’ve spent enough time, money, and perhaps health trying to fix this. I give up and would love to speak with someone at Aillio or Sweet Maria’s about taking this roaster back or exchanging it. I am certain fumes are leaking from the roaster itself when they shouldn’t. It’s not healthy or usable.
Sorry to hear that. This is so unfortunate.
I hope the Aillio team will fix this issue very soon.
All the best
Hi @ibnabouna, I bought a device to check the PM 2.5 to to check the air quality so I can share my finding with you. The issue that I’m having now is that the numbers on the new device are off from the other two devices that I have so I can’t even confirm if it is credible or not! (just the CO2 against the device on the right, and humidity and temperature against the device on the left and the one on the right)!
Sorry, I really wanted to be of any help, but I’m not sure how accurate the device is.
Greetings,
Just a brief update for those following this thread. I’ve heard from several here and on other roaster forums/groups that they are very interested in what happens with my situation, so here is the latest.
  1. I dismantled my ventilation set up for now and moved the roaster to a place underneath a window. I then used an AC Infinity venting bracket to mount a 6" hose to the window. I connected the AC Infinity S6 fan to that hose. I then mounted a duct boot from the S6 fan to be directly above the exhaust port of the roaster with an air gap as recommended by Aillio. This is the most basic and simple ventilation solution; the total run was less than 3 ft. Despite this, my air quality monitors still reported high PM 2.5 at dry end and first crack.
  2. I contacted Sweet Maria’s, the U.S. retailer from which I purchased my Bullet R2 Pro in January 2025, and requested either a refund or a 1:1 exchange. They seemed polite about it, but didn’t offer any assistance other than to tell me that all support had to go through Aillio. They included Aillio in the e-mail and then waited to see what Aillio said.
  3. Someone from Aillio called me from Taiwan. He was pleasant and seemed genuinely concerned to help me. We had a good conversation about potential causes and all the steps I took. He also said he was reading all the posts in this thread. We finally agreed on exchanging the roaster in case there was an issue with my specific unit.
  4. Aillio sent an e-mail to Sweet Maria’s saying, ā€œPlease arrange a pickup for ------'s current Bullet and ship him a replacement to test.ā€ He also asked me, ā€œPlease keep us updated on your findings.ā€ The clear meaning of this message was that Sweet Maria’s would send me a replacement, arrange for pick up of my Bullet, and I would update them about the findings. I was OK with that resolution and agreed not to seek any more remedy if the replacement unit behaved in the same way.
  5. A couple of days later, I received an e-mail from Sweet Maria’s basically saying, "OK, let’s start the process of the exchange by you shipping us your roaster so we can test it out. There is a good chance we won’t find anything wrong with it in which case we’ll just send it back to you. If we do find something wrong, then we’ll keep it and ship you a new one. However, we don’t have any new ones and will have to wait for Aillio to make more at some point in the future and send them to us.ā€
  6. I advised Sweet Maria’s that this is not what Aillio and I agreed on. Although my message was to Sweet Maria’s, Aillio responded and said, basically, ā€œYes, but now support has to go through Sweet Maria’s and we never promised to exchange the roaster immediately. You have to go through the process with Sweet Maria’s.ā€ Of course, this is a direct contradiction of what Aillio wrote to me and Sweet Maria’s:
Sadly, it seems as though they changed their mind about helping me and I am back to square one. This is very disappointing customer service from both Aillio and Sweet Maria’s.
Disappointing behaviour from both. Sorry Abouna you are having to go through this bad experience
As a periodic update, I am unfortunately still at a stalemate with Aillio and Sweet Maria’s.
After explaining that we had agreed to just exchange the roaster in light of all the videos and data I’ve shown concerning the unhealthy fumes, the nice representative from Aillio said it was a misunderstanding and that he would reach out to his supervisor for additional guidance as to the next steps.
That was a week ago and I haven’t heard anything since.
In the meantime, to fulfill orders for my church, I am forced to use the roaster outside while standing far away.
God willing, I hope this can be resolved soon.
It has been a while, but I wanted to share an update. After some discussions with Aillio, they kindly agreed to swap the roaster. My R2 Pro is scheduled to be picked up today, and after confirmation of pickup, the US retailer, Sweet Maria’s, will ship out a new one from the recent batch.
All in all, I’m satisfied with this result and praying all will be well with the replacement. It restores my enthusiasm for Aillio as a company and its customer service.
