I’m needing to access the exhaust fan motor for removal/replacement. I know how to remove the fan but I’m stuck at not knowing how to access the motor itself. How do I open up that area of the Bullet?
Remove the chaff filter side of the back of the Bullet as you normally would to clean out the chaff trap.
There are four holes in the metal plate on the remaining side, use the Torx wrench (IIRC) from the toolkit to remove the screws accessible through these holes. This should allow you to remove the housing from this side of the back of the Bullet and access the motor and PCB from there.
Or, watch this video.
THANK YOU. That’s what I needed.
