Introduction
As you likely know, we released RoasTime v4.3.2 publicly back in March. Within the past 3 months, you have done 35,604 roasts on RT4 already!
As business as usual, we have been fixing bugs and implementing new features as we go. Once in a while, that requires a “main” change. Your main version is the “v4.3.2” you see when you open the application. Unfortunately, we discovered a bug in our Windows updater that necessitated this force upgrade.
Due to that, we have upgraded RoasTime main to v4.6.6. So what can you expect?
- Your application should update itself in the background and will take on the new main version when you restart the application (assuming you left it open long enough to update). If it does not or you run into any issue, you can get it from roastime.aillio.com.
- You may need to unplug and restart your Bullet after upgrade.
- Your “Latest Versions” in the config section will temporarily show less than the actual version you are on. This is due to minimum version requirements we made with this main version and this will rectify itself when we upgrade those dependencies.
What Changes?
TLDR; there has been lots of changes since we released out v4.3.2. As you know, your versions change constantly. But I want to point out a few big leaps that are included with v4.6.6.
- Fixed a Windows updating issue.
- Fixed a MacOS “CMD+Q” bug that disallowed other applications to exit.
- Added functionality to make upgrades more granular (os-specific, user-specific)
- LibUSB upgrade from 1.0.24 to 1.0.26
- Some pretty hefty comms changes to support the LibUSB upgrade, fix issues with disconnection on PRS and other related issues
- Improved logging
Conclusion
As usual, you can expect us to keep releasing fixes and features within our dependencies. We will soon be releasing some UI improvements as well other other features. Please reach out with any questions or issues.
