Just got new Bullet feb 2021, and have problem to connect RT3 (like many others, just cant find solution in the forum)
Where to locate the driver and any idea how to Forcing Roastime 3 Driver Installation?
If I go to DL driver in RT3, its will try do something if I chose folder with some files inside, but nothing if happens, if I choose empty folder just nothing, I made a video here Roasttime 3 driver? - YouTube
So this is actually my fault. It seems I broke this in the last version. I DO have a fix for it, but I was trying to get some other stuff also in with the release. In the meantime, you can download the drivers by:
mcaillio, I have the same sort of issue. Have tried using the 3.1.7 route and it seems to just sit with a dos popup open saying it is installing, I gave up after 1/2 hour. I also went the other route above using zadig and it timed out. Can you help please.
Thanks.
Steve.
