Software not working
help, I started roastime and it said to restart, which I did, it then rebooted my computer for some reason and now I get this error:
Error: backend/unavailable
Failed to connect to RoasTime’s backend after retrying 5 times. Restart RoasTime to try again.
every time I restart, I get this message
It is so frustrating to have constant updates thrust upon us. I’d much rather choose when to install updates. I needed this time to roast, now I am winging it on the roaster without seeing the time/temp graph.
Some things I would try in that situation are restarting the computer, reinstalling the software, and/or reinstalling the USB drivers.
I have tried reinstalling the software and rebooting the computer. How do you go about reinstalling the USB drivers?
Go to Settings > Edit Settings > Software > Re-install
You might also check out this post where somebody else was experiencing a similar issue:
Can you please tell us which versions you are using?
Go to settings → Software (like the previous post).
Jacob, Matt Yau was able to solve this problem by having me delete the following folder on my windows PC:
c:\users\username\AppData\Roaming\RoasTime
All good now! Thanks Matt!
The software wouldn’t even start, so not possible to do this.
