I am roasting on Debian Testing with latest RoasTime 4, no problems so far. My last successful roast was on May 9th.
When I wanted to roast yesterday, however, RoasTime crashed with a SEGFAULT in the Chromium process. I am not 100% sure if it was right away or after the usual update-restart. Anyway, it seems to have something to do with window size. When I reduce window size to
then the app starts. The weird thing is that I had it running with a wider window as well, but when I tried to find the breaking window size I had to go down further than before. That is at some point it worked with width 1600, but now it doesn’t.
Before I had the window maximized, but when I do that now the app crashes right away.
On windows there is a file called “window-state.json” which saves the last state of the window (not sure about Linux). Perhaps this is corrupted or set out of bounds? You could try deleting / changing it. On windows it is found in: …\AppData\Roaming\RoasTime
@sturmdcwm Which specific version are you running on the main process? Is it 4.6.36? I did a large upgrade of Electron in the latest version, so I wonder if there was a breaking change with this.
Does this only happen on startup? I assume you can make the window bigger after the fact?
Yes, I run 4.6.36. I can resize the window at will while the app is running, but then it segfaults on restart. However, maximizing the windows crashes the app right away.
Me too - I am also hoping for a new linux release “soon”. Any update?
I can work around the segmentation fault, but I can’t shrink the window vertically, it is too big such that the roaster controls fall below the screen, so I can’t control the roaster.
Slightly related - where are release notes or notifications of releases for linux posted? Is the only way to see if there is a new release, to download it and see if the number in the appimage file is higher than what we downloaded last time?
