Bullet V1.5 F/W 558
On October 16 my Bullet upgraded to 3.2.5.
Issue #1
On my 2nd roast of a Back to Back session, the RT graph froze about halfway through the roast. I was able to finish it using the control panel.
Today, 10/26, I roasted 2 batches BTB and during both of the Pre Heat periods the same RT graph freeze occurred. Each time I restarted RT while the Bullet continued pre-heating, and the PH time-elapsed picked up where it should be, but of course the graph restarted. Each roast then completed with no problem.
I upgraded the Firmware to Beta 602 after these roasts, but did not have time to roast again as a test.
Issue #2
I also noticed that the Info button at the top right had disappeared. I was able to hover the mouse over where it should be, to the right of the pencil, and the pointing finger appeared…I clicked the blank space and the Info box appeared. My screen background color is white. I did look at this quickly after upgrading the Firmware to Beta 602 and the Info Button is still in ghost mode.
Any thoughts? Thanks.
