Segmentation Fault when loading RoasTime AppImage
Hello.
I try to run RoasTime 4.6.36 (for linux) on ElementaryOS but got “segmentation fault” message.
I 've been using RoasTime on ElementaryOS for months with no problem.
Any suggestion would be appreciate.
Thanks in advance
I try
sudo ./RoasTime-4.6.36.AppImage --no-sandbox
I got the blank window of RoasTime.
Can you try backing up these 2 directories, then removing them:
rm -rf ~/Library/Application\ Support/roast-time
rm -rf ~/Library/Application\ Support/RoasTime
and starting again to see if it starts up?
This sounds similar to another user who found an issue with the screen size causing a Segfault on the latest version: Roastime crashing
It works. Thanks.
By the way, my system doesn’t have ~/Library/Application/…
so I do this
rm -rf ~/.config/RoasTime
rm -rf ~/.config/roast-time
then run appimage and it works :slight_smile:
After launching the app, it sync with server and everything looks good. Do I have to restore the backup files?
Nope - you are good. FYI, I found the issue here: Roastime crashing - #6 by mcaillio
