Hi, we are aware of a build issue causing connection issues for some of you. If you are affected, you need to delete dependencies before restarting the app.
Update:
We have released a new RoasTime version that will fix this issue by installing the new version. Please go to https://roastime.aillio.com and install the latest version (v4.8.1 for Windows and v4.8.0 for MacOS and Linux) to rectify this issue. Alternatively, see the below original post.
Again, apologies. Thank you for your understanding.
Original Post:
Hi, we are aware of a build issue causing connection issues for some of you. If you are affected, you need to delete the dependencies folder before restarting the app.
MacOS terminal command:
rm -rf ~/Library/Application\ Support/RoasTime/deps
Windows terminal command:
rd /s /q C:\Users\"YOUR USER NAME"\AppData\Roaming\RoasTime\deps
As an alternative to the above commands, you can manually remove the “deps” folder at the following location depending on your operating system. Hidden files/folders may need to be enabled first before attempting this.
Windows
Path:C:\Users\"YOUR USER NAME"\AppData\Roaming\RoasTime\deps
How to view hidden files on WindowsMac
Path:~/Library/Application\ Support/RoasTime/deps
How to view hidden files on MacWe apologize for the inconvenience and for not posting sooner but we didn’t realize it was effecting many people. Steps are being taken to ensure this doesn’t happen again.
